Enable full command line in console output
miskol
Post by miskol »
I am building project like this
msbuild /verbosity:normal /consoleloggerparameters:ShowCommandLine /t:build /p:Configuration=Release /p:config=Release MyGroupProject.groupproj
And is it possible to see full command line how TwineCompile build every file
I know that it is all in twfiles.@@@ file
But I want to see that in console. google gemini told me about /p:TwineCompileLogging=Verbose but I can't find anything so it is pure LLM hallucination :mrgreen:
It will be nice if twinecopile will follow settings from /consoleloggerparameters:ShowCommandLine :mrgreen:
Re: Enable full command line in console output
Would it be possible to share why you need to see this information?
For all builds, except for Win64 Modern, TwineCompile doesn't actually use a command-line build - it directly invokes the compiler DLL and passes the arguments into it, so there isn't a true 1-1 mapping available. If you're looking for the options for each file, twfiles.@@@ is the source, as you have discovered.
