C++ Builder XE2
C++ Builder XE2
Is currently possible to use TwineCompile with the new XE2, or do I have to wait for a new version?
Thanks in advance!
Re: C++ Builder XE2
Unfortunately, you have to wait for the new version. Due to time constraints, we were unable to get the new version out at the same time as the XE 2 release.
Re: C++ Builder XE2
OK I can understand this ;)
When do you plan to release a new version which is compatible to XE2?
Are there any plans?
Re: C++ Builder XE2
We're planning to release it in a couple weeks.
Re: C++ Builder XE2
Would there be any beta to test? ;)
Re: C++ Builder XE2
Possibly, but it's not likely.
Re: C++ Builder XE2
Are there any news?
The standard IDE needs 1,5h to compile the whole project group.
With your great "plugin" we only need 15 minutes...
Re: C++ Builder XE2
We're still working on it. We'll notify all registered users and place announcments on the blog when it's ready.
Re: C++ Builder XE2
Thank you for releasing a XE2 compatible version.
But after installation with my XE2 Update2 I don't get TwineCompile only standard compiler runs. There is no item in toolstrip menu under "Tools" with TwineCompile.
What can I do?
Re: C++ Builder XE2
Try re-installing it. If there is no top-level menu called TwineCompile, then the plugin was not installed in the IDE.
