When I compile a unit and if there's an error, then TwineCompile 5.5.1 (current GetIt version), seems to be the reason for the following error message thrown by C++ Builder 11.3 (Patch 1):
Gitterindex außerhalb des zulässigen Bereichs.
(German, means sth. like "Grid index is outside the allowed range.")
The message details shows the following stack trace:
[5844A1ED]{vcl280.bpl } Vcl.Grids.InvalidOp (Line 928, "Vcl.Grids.pas" + 1) + $E
[5844F7A0]{vcl280.bpl } Vcl.Grids.TCustomGrid.MoveCurrent (Line 3799, "Vcl.Grids.pas" + 2) + $10
[5844ECB4]{vcl280.bpl } Vcl.Grids.TCustomGrid.FocusCell (Line 3424, "Vcl.Grids.pas" + 1) + $9
[58452246]{vcl280.bpl } Vcl.Grids.TCustomGrid.SetRow (Line 5062, "Vcl.Grids.pas" + 0) + $12
[772E1848]{TwineCompilePluginCore110.dll} Unbekannte Funktion bei __dbk_fcall_wrapper + $FF78
[772F349A]{TwineCompilePluginCore110.dll} Unbekannte Funktion bei __dbk_fcall_wrapper + $21BCA
[583B6E7B]{vcl280.bpl } Vcl.ExtCtrls.TTimer.Timer (Line 3244, "Vcl.ExtCtrls.pas" + 1) + $E
[583B6D5B]{vcl280.bpl } Vcl.ExtCtrls.TTimer.WndProc (Line 3202, "Vcl.ExtCtrls.pas" + 4) + $7
[55B45C1C]{rtl280.bpl } System.Classes.StdWndProc (Line 18517, "System.Classes.pas" + 8) + $0
[58435263]{vcl280.bpl } Vcl.Forms.TApplication.ProcessMessage (Line 11488, "Vcl.Forms.pas" + 23) + $1
[584352A6]{vcl280.bpl } Vcl.Forms.TApplication.HandleMessage (Line 11518, "Vcl.Forms.pas" + 1) + $4
[584355E5]{vcl280.bpl } Vcl.Forms.TApplication.Run (Line 11657, "Vcl.Forms.pas" + 27) + $3
[005080A2]{bds.exe } bds.bds (Line 227, "" + 16) + $2
The TwineCompile-related lines translate to "unknown function at __dbk_fcall_wrapper ".
If I disable "Errors" in TwineCompile's "Compile Messages" panel, then the problem doesn't happen.
Gridindex out of range
Daytona675x
- Contact:
Re: Gridindex out of range
I've got this error too, but can't really why it happens. I think it has to do with some of the messages produced by the compiling, but haven't really tried to pinpoint this.
Same here.
If an error occurs during compilation, the "Grid index error" is displayed 90% of the time.
It would be nice if this could be corrected, as it is a bit tedious.
Can you download this file, extract into the TwineCompile Program Files directory and see if it resolves this issue:
https://jomitech.com/downloads/TwineCom ... ore110.zip
No, it doesn't help.
Maybe it depends on how the tools windows are docked.
Attached is a screenshot of my IDE.
- (182.29 KiB) Not downloaded yet
Daytona675x
- Contact:
Unfortunately it doesn't fix things here neither.
Here's my stacktrace:
[5896A1ED]{vcl280.bpl } Vcl.Grids.InvalidOp (Line 928, "Vcl.Grids.pas" + 1) + $E
[5896F7A0]{vcl280.bpl } Vcl.Grids.TCustomGrid.MoveCurrent (Line 3799, "Vcl.Grids.pas" + 2) + $10
[5896ECB4]{vcl280.bpl } Vcl.Grids.TCustomGrid.FocusCell (Line 3424, "Vcl.Grids.pas" + 1) + $9
[58972246]{vcl280.bpl } Vcl.Grids.TCustomGrid.SetRow (Line 5062, "Vcl.Grids.pas" + 0) + $12
[50391848]{TwineCompilePluginCore110.dll} Unbekannte Funktion bei __dbk_fcall_wrapper + $FF78
[503A349A]{TwineCompilePluginCore110.dll} Unbekannte Funktion bei __dbk_fcall_wrapper + $21BCA
[588D6E7B]{vcl280.bpl } Vcl.ExtCtrls.TTimer.Timer (Line 3244, "Vcl.ExtCtrls.pas" + 1) + $E
[588D6D5B]{vcl280.bpl } Vcl.ExtCtrls.TTimer.WndProc (Line 3202, "Vcl.ExtCtrls.pas" + 4) + $7
[58D25C1C]{rtl280.bpl } System.Classes.StdWndProc (Line 18517, "System.Classes.pas" + 8) + $0
[58955263]{vcl280.bpl } Vcl.Forms.TApplication.ProcessMessage (Line 11488, "Vcl.Forms.pas" + 23) + $1
[589552A6]{vcl280.bpl } Vcl.Forms.TApplication.HandleMessage (Line 11518, "Vcl.Forms.pas" + 1) + $4
[589555E5]{vcl280.bpl } Vcl.Forms.TApplication.Run (Line 11657, "Vcl.Forms.pas" + 27) + $3
[00AA80A2]{bds.exe } bds.bds (Line 227, "" + 16) + $2
I think I figured the issue out. Was very hard to reproduce as it was a timing issue with the message synchronization. Please download that file again, extract into the TwineCompile Program Files directory and see if it resolves the issue:
After a first quick test it seems to work correctly now.
Thanks.
Thanks.
