when compiling with TwineCompile 5.2 i often get this error "[C++ Error] TCTargets104.targets(658, 5): MSB6006 "mtbcc32" exited with code 1." when doing "Build". If i try to "Make" the project after the error it compiles fine. I am using bcc32c and bcc64 compilers, i haven't tested this on the classic bcc32.
Another problem that occurred to me a couple of time is a linker error "unresolved vtable for TForm2" when I do "Make". If I then do a clean and build it compiles just fine. I'm not sure if this is related to TwineCompile. (I have proper configuration of output directories so i don't have a clue why this is happening).
Best regards!
- Attachments
- (125.19 KiB) Not downloaded yet
Re: [C++ Error] TCTargets104.targets(658, 5): MSB6006 "mtbcc32" exited with code 1.
Can you provide the output from the Console Output tab in the compile window when you get that mtbcc32 error?
Here is the console output:
I am attaching a sample project that demonstrates the issue. The first time when you do Build all it will compile, after that if u do it again it crashes.
Preparing...
Building...
Build started 17.8.2020 г. 8:44:06.
__________________________________________________
Project "C:\Users\UserPC\Desktop\tc_crash_test\Package1.cbproj" (Build target(s)):
Target CleanLinkerStateFiles:
Deleting file ".\Win32\Debug\Package1.ilc".
Deleting file ".\Win32\Debug\Package1.ild".
Deleting file ".\Win32\Debug\Package1.ilf".
Deleting file ".\Win32\Debug\Package1.ils".
Deleting file ".\Win32\Debug\Package1.pdi".
Target TCInitFileList:
Deleting file "C:\Users\UserPC\Desktop\tc_crash_test\twfiles.@@@".
C:\Program Files (x86)\JomiTech\TwineCompile\mtbcc32.exe -ide104 -alias"C:\Users\UserPC\Desktop\tc_crash_test\Package1.cpp"="C:\Users\UserPC\AppData\Local\Temp\TwineCompile\Package1.cpp*1360085926"; -priority0 -clang -files="C:\Users\UserPC\Desktop\tc_crash_test\twfiles.@@@"
JomiTech TwineCompile 5.2 - Copyright JomiTech 2020. All Rights Reserved.
Compiling 2 files...
Embarcadero C++ 7.50 for Win32 Copyright (c) 1993-2020 Embarcadero Technologies, Inc.
Package1.cpp: (0) 0 of 0
Error: Borland option to build DLL was disabled in PCH file but is currently enabled
Error: macro 'USEPACKAGES' was undef'd in the precompiled header but defined on the command line
C:\Users\UserPC\Desktop\tc_crash_test\Unit2.cpp
Unit2.cpp: (1) 0 of 0
Compiled 2 files in 0,14 secs.
Errors during compile.
C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets104.targets(762,5): error MSB6006: "mtbcc32" exited with code 1.
Done building target "TCCompile" in project "Package1.cbproj" -- FAILED.
Done building target "MakeObjs" in project "Package1.cbproj" -- FAILED.
Done building project "Package1.cbproj" -- FAILED.
Build FAILED.
0 Warning(s)
1 Error(s)
Time Elapsed 00:00:00.29
Finished Build.
Thanks for the test project, it was very helpful in reproducing the issue. I have attached a fix to this post - please download and extract into the TwineCompile Program Files directory (replacing the existing TCTargets104.targets file)
sorry for the late response, I just tested the update but it outputs the following error: Here is the output:
This is tested on the same demo project.
Best regards!
Preparing...
Building...
Build started 21.8.2020 г. 23:34:36.
Project "C:\Users\ilia\Desktop\tc_crash_test\Package1.cbproj" (Build target(s)):
Target TCBuildFileList:
Target TCCheckPCHState:
C:\Program Files (x86)\JomiTech\TwineCompile\TCTargets104.targets(420,3): error MSB4044: The "BccDependencyCheck" task was not given a value for the required parameter "OutputFile".
Done building target "TCCheckPCHState" in project "Package1.cbproj" -- FAILED.
Done building target "TCBuildFileList" in project "Package1.cbproj" -- FAILED.
Build FAILED.
0 Warning(s)
1 Error(s)
Time Elapsed 00:00:00.00
Finished Build.
Best regards!
My apologies, wrong file was attached. Please try this one.
- Attachments
- TCTargets104-2.zip
- (7.23 KiB) Downloaded 533 times
This one works as expected, thank you!
Hi I'm getting a similar error using C++ Builder 10.3.3 with Twine 5.2.1.250 on an empty project, do you have any new releases to fix this?
In case it's not the same cause, the actual error in my case seems to be:
Error: unable to read PCH file .\Win32\Debug\Project20PCH1.pch: 'no such file or directory'
Fatal: PCH file '.\Win32\Debug\Project20PCH1.pch' not found: module file not found
I've attached a similar fix for 10.3.3. Please extract into the TwineCompile Program Files directory - it should overwrite an existing file.
- Attachments
- TCTargets103.zip
- (7.23 KiB) Downloaded 480 times
