Background color DivWindow
dbrazoli
Post by dbrazoli » Wed Apr 03, 2019 7:34 am
Jon, I'm in need of your guidance again.
I want to put a background color in DivWindow. It's possible ?
Thankful.
Daniel.
Re: Background color DivWindow
Post by jomitech » Wed Apr 03, 2019 3:11 pm
Yes, you can use CSS to override the background color of the JTDivWindow.
dbrazoli
Post by dbrazoli » Wed Apr 03, 2019 3:46 pm
Jon, thank you again for your prompt response.
But I could not color the divwindow background.
I used jquery like this:
$ ('#dvtelalogin'). css ("color", "silver");
or
$ ('#dvtelalogin'). css ("background-color", "silver");
But it changes the color only from the edge, not the background.
Are there any other selectors to set?
Thankful.
Daniel.
Post by jomitech » Wed Apr 03, 2019 5:59 pm
You need to set the actual background object, not just the parent element.
$('#dvtelalogin span.jtdivwindowcontents').css("background", "silver");
dbrazoli
Post by dbrazoli » Fri Apr 05, 2019 8:26 am
Jon, I applied this style in the DivWindow onshow event, $ ('# dvtelalogin span.jtdivwindowcontents'). Css ("background", "silver"), but now changed only the border color of 2 edits.
Also onload, on ready and onpageheader.
I also used the gradient property, at design time the background color is changed to the desired one, but at run time it goes blank.
Is there anything else to be done?
thankful
Daniel.
Post by jomitech » Fri Apr 05, 2019 2:28 pm
What theme are you using?
dbrazoli
Post by dbrazoli » Fri Apr 05, 2019 3:23 pm
I use default, blue
Post by jomitech » Fri Apr 05, 2019 7:52 pm
Sorry, use this instead:
$('#dvtelalogin .jtdivwindowcontentsframe').css("background", "green");
dbrazoli
Post by dbrazoli » Fri Apr 12, 2019 6:52 am
Hello, Jon.
Great!
Where could I find a list with these properties?
Thankful.
Post by jomitech » Mon Apr 15, 2019 9:16 am
It's just basic CSS properties, being set using JavaScript. See https://www.w3schools.com/cssref/default.asp
