Help with JTProgressbar
dbrazoli
Post by dbrazoli » Fri Oct 06, 2017 7:52 pm
Hello, Jon.
I hope all is well with you.
I need your precious help.
I am using the JTProgressBar example. I found it very interesting.
But I would like it when it reaches 100% the window closes automatically.
I saw the routine that there is a WaitWindow.hide () command, but the window does not close.
Would you help me ?
Grateful.
Daniel.
Re: Help with JTProgressbar
Post by jomitech » Mon Oct 09, 2017 10:22 am
Change the following line of code to make the window automatically close:
$ajaxResponse->addScriptCall( "stopProgress" );
to:
$ajaxResponse->script( "stopProgress" );
dbrazoli
Post by dbrazoli » Mon Oct 09, 2017 12:05 pm
Thank you Jon.
I will do the change and test and I will return the result.
Grateful.
dbrazoli
Post by dbrazoli » Tue Oct 10, 2017 5:49 pm
Hello, Jon.
I did as you told me, but it did not work.
Even at the end of the loop up to 100% the window will not close.
Here's how the code looks.
private function FinishProgress()
global $ajaxResponse;
$ajaxResponse->script("stopProgress");
$tempFile = $this->TempFileName();
if( file_exists( $tempFile ) )
unlink( $tempFile );
Is there anything else to be done?
Grateful.
Daniel
Post by jomitech » Thu Oct 12, 2017 4:35 pm
Try putting this:
$this->FinishProgress();
At the end of the Button1Click method.
dbrazoli
Post by dbrazoli » Thu Oct 19, 2017 6:57 am
Hello, Jon.
Unfortunately their suggestion did not work.
Is there any other way to do this?
Grateful.
Post by jomitech » Fri Oct 20, 2017 1:32 pm
What browser are you testing this in? And can you send me your file?
dbrazoli
Post by dbrazoli » Sat Oct 21, 2017 1:38 pm
Hello, Jon.
Now I was embarrassed, (laughs ...)
I was using google chrome and firefox.
But inexplicably now it's working ..
I think maybe it was the cache.
You can breathe easy now ... (laughs again) ..
Grateful.
Post by jomitech » Sat Oct 21, 2017 3:41 pm
Excellent, glad to hear it's working for you.
dbrazoli
Re: Help with JTProgressbar - Yet
Post by dbrazoli » Wed Nov 01, 2017 8:47 am
Hello, Jon.
I tried incorporating Progressbar functionality into my query reading routine, as an example while (! Query.eof) {
// here I generate an excel spreadsheet
But I could not. The browser simply does not execute.
I used the JtprogressBar example, copying the functions.
Would you help me by pointing out exactly where to call each function, eg startprogress and etc ...
Grateful.
Daniel
