Error installing jomitech components
LEONARDO19712
Re: Error installing jomitech components
Post by LEONARDO19712 » Thu Dec 15, 2016 7:13 am
Hello sorry but my problem is not connection that is already solved my problem is connection with the library jomitech if you look at the log appears this error:
PHP Strict Standards: Declaration of JTCenteredPage::dumpChildrenHeaderCode() should be compatible with Component::dumpChildrenHeaderCode($return_contents = false) in /home/servicesta/public_html/presentacion/rpcl/components4phpfull/jtcenteredpage.inc.php on line 13
Post by jomitech » Mon Dec 19, 2016 5:18 pm
Did you add the PHP error line below the <?php tag at the top of your file?
error_reporting(E_ERROR | E_WARNING | E_PARSE);
LEONARDO19712
Post by LEONARDO19712 » Tue Jan 03, 2017 8:59 am
Hi, it is not active
