help JTCenteredPage
LEONARDO19712
help JTCenteredPage
Post by LEONARDO19712 » Mon Jul 20, 2015 4:37 pm
Hi Jon am trying to run my application locally appserv and I can not make it work because I shows the following error
Fatal error: Declaration of JTCenteredPage::dumpChildrenHeaderCode() must be compatible with that of Component::dumpChildrenHeaderCode() in C:\AppServ\www\bpm\presentacion\rpcl\components4phpfull\jtcenteredpage.inc.php on line 13
Fatal error: Call to a member function serializeChildren() on a non-object in C:\AppServ\www\bpm\presentacion\rpcl\forms.inc.php on line 53
but this does not happen when I run the application from a Web server, I can help, you know what happens? Thank you.
Re: help JTCenteredPage
Post by jomitech » Sat Jul 25, 2015 1:56 pm
Are you running the same copy of the RPCL on both your local server and the web server?
LEONARDO19712
Post by LEONARDO19712 » Mon Jul 27, 2015 5:20 pm
usually if I copy the entire directory
LEONARDO19712
Post by LEONARDO19712 » Mon Jul 27, 2015 7:57 pm
I was checking and is the same copy that is on the web server and which I have on the local server
