Duplicate records on Insert to Detail grid.
PlatinumGrid - Full version
Dmilpsu
Post by Dmilpsu » Fri Jan 27, 2017 6:31 pm
I can't find a workaround for this. I have the key set, I have autoinc set to yes in the table component. The tables are set in a master-detail at table component level. I populate the link field which points to the parent record in the onrowinsert routine. A check of the SQL log shows two insert commands issued. If necessary, I can do a workaround if I can override the action of the Insert button.
staffnote.zip
(17.88 KiB) Downloaded 232 times
