missing rows when canscroll set to False
PlatinumGrid - Full version
Dmilpsu
Post by Dmilpsu » Sun Jun 19, 2016 8:32 am
I am using multiple grids to display a status, no scroll is needed either vertical or horizontal.
in the columns property I set the CanEdit to CanSort to false. The column takes on a gradient look which is fine, but when I run it, only two out of three rows is displayed. The status bar at top says 3 rows, but only two are visible. When I enable CanScroll, it works without issue.
I have set up the grids for readonly, no row selection.
Re: missing rows when canscroll set to False
Post by jomitech » Mon Jun 20, 2016 8:29 am
CanScroll for a column is used to control whether the column is a "fixed" column. In other words a column that does not scroll horizontally, but is always visible.
If you want to disable scrollbars, just make the grid big enough to fit all your data.
Dmilpsu
Post by Dmilpsu » Thu Jun 30, 2016 4:21 pm
The size of the grid is far greater that the size of data. It can hold about 30 rows, yet one 2 out of three rows are visible. Can't understand why one row is not displayed
Post by jomitech » Tue Jul 05, 2016 7:41 am
Can you post a screenshot, or possibly a simple test case that I can run locally?
Dmilpsu
Post by Dmilpsu » Thu Aug 04, 2016 7:32 pm
will try to soon
